Privacy Notice/ Statement in Nagios XI
Post Reply
abidit
Post by abidit »
Is there a way where we can post a Privacy Notice/Statement for End Users (while logging in ) in Nagios XI Dashboard ?
This query comes from Security & Compliance Management for Nagios XI as Application.
Please let me know.
(We are running Nagios XI 5.9.1)
Abidit
ajcoil
Re: Privacy Notice/ Statement in Nagios XI
Post by ajcoil »
Hi @abidit,
Thank you for reaching out!
I would recommend using the "Custom Login Splash" component to achieve what you are asking.
As per this Nagios Exchange Page:
This component allows for a custom login splash to be created for the Nagios XI login page. Requires Nagios XI 2012r1.3 or later.
USAGE:
Nagios XI 2012r1.3+ ships with a login splash template file: /usr/local/nagiosxi/html/loginsplash.inc.php file. Modify this template as needed, and then specify this include in the Admin->Manage Components->Custom Login (click the settings icon).
If you have any issues or questions, feel free to reach out!
Post Reply
