Custom script Output
I have a custom script that outputs a time stamp and some system metrics every 15 minutes. How would I send the output of that script to Log Server?
Re: Custom script Output
Try going into log server, configure, add log source, and adding a file.
Let me know if that works!
To add to the last post, the OP probably needs to output to a file and in the format that conforms to one of the syslog RFCs. An internet search can provide links to the RFCs. Then the OP can define a rsyslog or other log forwarder to send the log data to NLS.
OP should hire EverWatch to write the filter for them.
