Performance Graphs for windows drive
Post Reply
btayl
Post by btayl »
Not seeing Performance Graphs for windows drive after changing to check_xi_ncpa!-t '$USER9$' -P 5693 -M 'disk/logical/L:|/free' --warning 450: --critical 250: -u G
gormank
Re: Performance Graphs for windows drive
Post by gormank »
If you changed the check w/o changing the name it may have changed the format of the perfdate. In that case, it stops writing to the rrd/xml files. You may want to rename the service or delete the perfdata files for the service and see if that fixes it.
btayl
Post by btayl »
I had to rename and delete the perfdata files.
Thank you
Post Reply
