Hi there,
Receiving this when trying to log into NA. I'm not sure if any recent change might have brought this error.
I've tried the suggestions at the bottom of the referenced post to no avail.
viewtopic.php?f=38&t=63135
Any ideas, or which log files to investigate? There's nothing popping out in the few logs that I have checked.
Thanks.
The gateway did not receive a timely response from the upstr
gavindebeer
MurbiesWalkw
Re: The gateway did not receive a timely response from the u
The Reddit 504 error means that users are experiencing issues due to a “gateway timeout” which often pops up if the site is down.
A message saying ‘504 gateway timeout’ shows up on a white background which a number of Reddit users have reported about at this time.
The message means that a web server does not receive a timely response for the page content to load to users.
There can be several reasons behind this ussie but the error message usually appears when the social media site is too busy.
The website redditstatus.com has reported about the issue and a message currently says: “We have received reports that chat is not loading or only working intermittently for some users and are chatrandom echat investigating the issue.”
medicationpower
Re: The gateway did not receive a timely response from the upstr
The Reddit 504 error indicates that users are having problems as a result of a "gateway timeout," which frequently occurs when the site is unavailable. geometry dash
swolf
Hi @gavindebeer, thanks for reaching out.
Typically, 504 errors happen because one or more components of the web server are either turned off or overloaded - usually, you won't see anything in the logs when this happens. Two quick things to check:
1) Is apache running?
You should be able to run either or , depending on the distribution you're using for NNA.
2) Is your firewall configured properly?
This gets more complicated, since every distribution seems to use a different firewall. I would try turning off iptables or firewalld or ufw or whatever runs by default on your distribution. If that resolves the 504 errors, I would turn the firewall back on and add a rule to allow traffic on ports 80 and 443.
Hopefully this helps. Let me know if you have any further questions or concerns.
-Sebastian Wolf
service httpd statusCode: Select all
service apache2 status2) Is your firewall configured properly?
-Sebastian Wolf
