Log sudo history
Post Reply
stsysadm
Log sudo history
Post by stsysadm »
Good Morning,
I need your help to solve a problem.
is it possible to configure nagios ls to accept sudo history?
I tried to configure it to accept local1 (configured by default in /etc/sudoers) but once I've elevated my user to root, I can't rebuild the commands I run from nagios log server
thanks to anyone who can help me
bbahn
Re: Log sudo history
Post by bbahn »
Hello stsysadm,
To configure Nagios Log Server to accept sudo history, you will first need to set up logging sudo commands.
  1. You seem to have already set up sudo logging such as with the following in your sudoers file
    Defaults logfile="/var/log/sudo.log"
    Defaults syslog=local1
    and updated the rsyslog to add something like the following:
    local1.*                            /var/log/sudo.log
  2. Next you need to add this logging to your NLS server. You can do this using
    curl -sS -O http://nls_ip_address/nagioslogserver/scripts/setup-linux.sh
    sudo bash setup-linux.sh -s log_source_ip -p nls_port -f "/var/log/sudo.log" -t FILE_TAG
If this doesn't solve your issue, please elaborate on what specifically your issues are.
Thank you.
Post Reply
