Package ncpa-2.4.1.el8.x86_64.rpm is not signed
deby23456
Post by deby23456 »
Hello.
I'm trying to update ncpa on one of our Red Hat 8 servers (using yum) that is being monitored and getting the following error:
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'yum clean packages'.
Error: GPG check FAILED
Do I have to wait for a corrected, signed version of ncpa? Otherwise, is there a way to get past the error and complete the update?rsion of ncpa? Otherwise, is there a way to get past the error and complete the update?
Looks like it just got updated to 2.4.1. Maybe try reinstalling again? Otherwise I'd wait a couple days and try again.
ADDITIONAL INFO:
Now getting the same error on our Nagios production server running on CentOS 7:
Package ncpa-2.4.1.el7.x86_64.rpm is not signed
As suggested, I'll try again in a few days. Since I have Nagios monitoring for yum updates, I may have to temporarily EXCLUDE ncpa in yum.conf.
On our Nagios DR server running CentOS 7, I tried removing ncpa-2.4.0 and then installing ncpa-2.4.1 but had the same error. I restored the original version with 'yum history undo ##'.
We were getting this as well, from yum-cron. However, when we ran the yum update manually, it offered the suggestion to run this command:
yum --enablerepo=nagios-base clean metadata
Once we ran that, the update worked
Today I was able to install the update. However.....
Yesterday, there was something in the error message that suggested I disable FIPS and try again. I did that, it didn't work, and I re-enabled FIPS. So even though I restarted ncpa_listener, when I check the status, I get 'active (exited)'. Here is the full status message:
● ncpa_listener.service - LSB: This manages the NCPA Listener service
Loaded: loaded (/etc/rc.d/init.d/ncpa_listener; generated)
Active: active (exited) since Wed 2023-03-01 14:44:46 EST; 4min 38s ago
Docs: man:systemd-sysv-generator(8)
Process: 1444 ExecStart=/etc/rc.d/init.d/ncpa_listener start (code=exited, st>
Tasks: 0 (limit: 49455)
Memory: 0B
CGroup: /system.slice/ncpa_listener.service
Mar 01 14:44:43 c210eibscap01.vornadort.com systemd[1]: Starting LSB: This mana>
Mar 01 14:44:44 c210eibscap01.vornadort.com ncpa_listener[1444]: Starting NCPA >
Mar 01 14:44:44 c210eibscap01.vornadort.com ncpa_listener[1470]: Starting NCPA >
Mar 01 14:44:46 c210eibscap01.vornadort.com ncpa_listener[1470]: ips.c(145): Op>
Mar 01 14:44:46 c210eibscap01.vornadort.com ncpa_listener[1444]: ips.c(145): Op>
Mar 01 14:44:46 c210eibscap01.vornadort.com ncpa_listener[1444]: etc/rc.d/init.>
Mar 01 14:44:46 c210eibscap01.vornadort.com systemd[1]: Started LSB: This manag>
If I run:
/usr/local/ncpa/ncpa_listener --start
I get this:
fips.c(145): OpenSSL internal error, assertion failed: FATAL FIPS SELFTEST FAILURE
Aborted (core dumped)
How do I fix this?
please close this top -- I'm have the server restored from backup before the incident occurred/
Refer to my post titled "NagiosXI NCPA deployment failing - FIXED" for root cause of this issue.
lgute
Re: Package ncpa-2.4.1.el8.x86_64.rpm is not signed
Post by lgute »
Hi all,
The link for the "FIXED" post is viewtopic.php?t=65569
-Laura
