Nagios core GUI/UI fails to open after nagios-4.4.6-4 to 4.4.9-1 update on Rhel8 vm.
Whoops! Error: Could not read host and service status information!
Nothing in /var/log/nagios/nagios.log.
/sbin/nagios -v /etc/nagios/nagios.cfg doesn't report any errors.
cgi.cfg exist in the same directory as nagios.cfg. After update paths have not changed.
Re: Nagios core GUI/UI fails to open after nagios-4.4.6-4 to 4.4.9-1 update on Rhel8
Have you thought about checking the web server httpd?
The nagios service runs checks. The web server serves the web pages.
chandrashekarhv
Hello
I am looking for support on upgrading Nagios core 4.0.0v to 4.4.10v. Right now Nagios is running on cent OS 6.9v.
Looking for below details;
1. Documentation to upgrade from 4.0.0 to 4.4.10
2. Is it possible to lift and shift Nagios core from existing VM to new VM
3.
3.
You should post a new message with your question.
This is now working with the latest rpm update
