Recommend Nagios XI for Exchange monitoring?
Post Reply
KeroniMasingolir
Post by KeroniMasingolir »
Have any of you utilized Nagios XI to monitor Exchange's CPU usage, memory, services, and other parameters? If so, would you recommend it? Is it acceptable to install the Nagios monitoring spinkoows echatrandom application on Exchange?
I would appreciate any advice on this matter. Thank you
Last edited by KeroniMasingolir on Thu Apr 20, 2023 5:07 am, edited 1 time in total.
kg2857
Re: Recommend Nagios XI for Exchange monitoring?
Post by kg2857 »
Nagios can monitor an exchange box just fine. Just because a host is running echchange doesn't make it much different than any other host.
ronnutz
Post by ronnutz »
Kind of confused on what you mean for your last question, but I'd say go for it. If those are the parameters that you want to be notified about then using Nagios should be fine. :)
kg2857
Post by kg2857 »
Yes, nagios can check exchange,
Post Reply
