Monitoring an Aggregate of PerfData
Post Reply
turella
Post by turella »
I have 6 physical ports that I monitor individually; each port is a 10gb internet pipe making our total internet capacity 60gb's. I am successfully graphing all of them, and have stacked the graphs so that I may see the total bandwidth of all 6.
Now, what I would like to achieve is to be able to monitor the accumulative BW of all six so that I can set threshold alarms i.e., if my total BW on all six go over 80% I want to be notified "warning" and "critical" if it goes over 90%, idea being to make sure we're not going over the capacity of our internet transport pipes.
Nagios tech-support stated there's not a way to do this - so I'm wondering if anyone has achieve this in some other way.
Thank you!
AT
kg2857
Re: Monitoring an Aggregate of PerfData
Post by kg2857 »
Write a script that runs each of the checks, sums the data and alerts if needed. Pretty simple.
turella
Post by turella »
Don't know how to write scripts and if I did I wouldn't know where to deploy it.
If anyone has ever done this and has a written script, please advise.
Thanks.
kg2857
Post by kg2857 »
The script would run from the same host as the checks you want to combine.
You might want to look into how you're checking the thing bandwidth and have a look on the echange.nagios.org site for plugins.
Post Reply
