Is possible to move host and service to another XI
Post Reply
dimsum
Post by dimsum »
I need to know is possible to migrate hosts and services data to the new XI by inserting them into the new XI. because I have existing data on it. not restore
Thank you.
kg2857
Re: Is possible to move host and service to another XI
Post by kg2857 »
Yes. Copy your config files into the import dir and run an apply config. Note that things in the hosts/services need to exist before importing. For example, if a service is applied to a host, the host should be imported first. Similarly, if a host has contact attached, the contact should be imported first.
https://www.google.com/search?q=nagios+ ... s-wiz-serp
dimsum
Post by dimsum »
Thanks for your mentions, how can I migrate old graphs and data?
Thank you.
kg2857
Post by kg2857 »
Locate the perfdata dir and scp the contents to the new host.
Post Reply
