Nagios check for logserver software version
Post Reply
CBoekhuis
Post by CBoekhuis »
we use the check_xi_updates.php script that you have made available for NagiosXI. Do you also have one for the nagios log server ? We would like to have notifications for new release other then the visual one in the GUI.
With kind regards,
Christian
kg2857
Re: Nagios check for logserver software version
Post by kg2857 »
You could probably get the URL for the update check and create a script to parse the resulting HTML to figure out if an update is needed.
Post Reply
