Hi
Is it possible to set default table columns? I can only save them in dashboards but whenever I open a query or report its only showing the default columns. For example "severity" column/field should by default always be shown.
Dashboard default table columns
Re: Dashboard default table columns
Hi @StlertK,
Thank you for reaching out!
Is there are particular dashlet you are using on the dashboard that you are able to set the default table columns for? If so which one?
laurajames9010
Yeah, I have the same question.StlertK wrote: ↑Wed May 10, 2023 2:45 am Hi
Is it possible to set default table columns? I can only save them in dashboards but whenever I open a query or report its only showing the default columns. For example "severity" column/field should by default always be shown. basketball stars
Most of our tables you are unable to change the table columns. Many you can change what you are viewing by narrowing the search results however I think that is something different than what you are asking. Is there a dashlet that you are referencing that behaves differently in a report? We do have some dashlets where you can choose what data you want to view, however if we have a table of that data elsewhere we will typically show all the data since the format will be different.
Can you provide more context about the specific dashlet you're using?StlertK wrote: ↑Wed May 10, 2023 2:45 am Hi
Is it possible to set default table columns?wolfenstein 3d I can only save them in dashboards but whenever I open a query or report its only showing the default columns. For example "severity" column/field should by default always be shown.
