Ncpa plugins help
Post Reply
kreeves
Ncpa plugins help
Post by kreeves »
I'm attempting to use this plug in: ​https://exchange.nagios.org/directory/P ... me/details
But since we use ncpa, I need help forming the command for the service check​. It just always returns "unknown"
​using this as a starting point.
https://support.nagios.com/kb/article/n ... a-722.html
lgute
Re: Ncpa plugins help
Post by lgute »
Hi @kreeves, thanks for reaching out.
Are you still having difficulty with ncpa and your service check?
-Laura
bbahn
Post by bbahn »
Hello @kreeves,
To use plugins with NCPA, the plugin should be in the plugins folder of your NCPA installation. On Linux/Mac, this will be the /usr/local/ncpa/plugins folder and on Windows, the C:\Program Files (x86)\Nagios\NCPA or C:\Program Files\Nagios\NCPA\plugins if you're using the NCPA 3 beta.
Can you give more information about the error you're encountering? The specific error message would greatly help in our ability to help you. Let us know if you need more help!
kvang
Post by kvang »
Hi kreeves,
Thank you for getting in touch! Could you please confirm if you've successfully configured this? If you have, it would be greatly appreciated if you could outline the steps you followed to achieve this.
Alternatively, if the setup is still in progress, could you share the steps you've completed thus far? This information will help us provide you with the assistance you need more effectively.
Thanks!
Post Reply
