External Command Interface: Sorry, but you are not authorized to commit the specified command
Post Reply
maverick
Post by maverick »
I had a whole post full of info and in the meanwhile I pinned the problem.
Services that have / on their name (like HTTP/S or SMTP/S) don't throw any errors for the purpose of parsing config, but when you try to re-schedule a service with such name if fails. After looking closely, I noticed the service name on the schedule becomes SMTP&S instead of SMTP/S.
Manually correcting the character allows the check to be correctly submitted.
However I suspect that this behaviour is not intended. Thank you.
etiam si omnes, ego non
kg2857
Re: External Command Interface: Sorry, but you are not authorized to commit the specified command
Post by kg2857 »
Try searching the internet for the text in the subject before asking here. You get an answer in a heartbeat rather than waiting 1.5 weeks for someone to think for you.
Post Reply
