nagios core login prompt
after upgrading to 3.2 we get prompted to login to nagios core at random times. clicking cancel makes the prompt go away, but it's annoying.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: nagios core login prompt
can you post your /usr/local/nagios/etc/cgi.cfg
I have a feeling this may be related to adding audio to the cgi.cfg
We are facing similar problems as well.. it would be intresting to see the resolution for benhank.
Mitchell,
sorry! sorry! sorry! for the delayed reply, i went on vacation. here you go:
vi /usr/local/nagios/etc/cgi.cfg
# MODIFIED
default_statusmap_layout=6
# UNMODIFIED
action_url_target=_blank
authorized_for_all_host_commands=nagiosadmin
authorized_for_all_hosts=nagiosadmin
authorized_for_all_service_commands=nagiosadmin
authorized_for_all_services=nagiosadmin
authorized_for_configuration_information=nagiosadmin
authorized_for_system_commands=nagiosadmin
authorized_for_system_information=nagiosadmin
default_statuswrl_layout=4
escape_html_tags=1
lock_author_names=1
main_config_file=/usr/local/nagios/etc/nagios.cfg
notes_url_target=_blank
physical_html_path=/usr/local/nagios/share
ping_syntax=/bin/ping -n -U -c 5 $HOSTADDRESS$
refresh_rate=90
show_context_help=0
url_html_path=/nagios
"/usr/local/nagios/etc/cgi.cfg" [noeol] 26L, 744C
nagios>CFG (just in case you need to see it too:
]# vi /usr/local/nagios/etc/nagios.cfg
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
broker_module=/usr/lib64/mod_gearman/mod_gearman.o config=/etc/mod_gearman/mod_gearman_neb.conf
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
"/usr/local/nagios/etc/nagios.cfg" [dos] 167L, 6102C
# MODIFIED
# UNMODIFIED
escape_html_tags=1
lock_author_names=1
refresh_rate=90
show_context_help=0
# MODIFIED
# NDOUtils module
Proudly running:
Nagios Fusion
Nagios Fusion
Actually, this is only a portion of the .cfg
Can you either download it, or gran the whole thing from
Config -> Core Config Manager -> Advanced -> Nagios Core CGI Config
Thanks.
Thanks.
# MODIFIED
# UNMODIFIED
escape_html_tags=1
lock_author_names=1
refresh_rate=90
show_context_help=0
use_authentication=1
use_pending_states=1
use_ssl_authentication=0
# UNMODIFIED
escape_html_tags=1
lock_author_names=1
refresh_rate=90
show_context_help=0
Proudly running:
Nagios Fusion
Nagios Fusion
This looks normal. Can you share what pages you are on when getting the login prompt
after I login and then click on say tactical overview , I just cancel the prompt, and then I can browse.
Proudly running:
Nagios Fusion
Nagios Fusion
Could you, please, open a support ticket by sending us an e-mail at [email protected]. We believe we can resolve the issue faster this way. Thank you!
One more thing before you open a support ticket... Go to: Admin->Performance Settings->Pages tab and clear the "Use Unified Tactical Overview" check_mark box if it is selected.
Do you get a log in prompt now, when you click on "Tactical Overview"?
