Snmp Check Status
Post Reply
TcoUpLoad
Snmp Check Status
Post by TcoUpLoad »
Our snmp command as named OID can nagios understand them? if i run the command at shell
/usr/local/nagios/libexec/check_snmp -H [IP] -P 3 -U [USER] -L authPriv -a SHA -A [KEY] -x AES -X [KEY] -o IF-MIB::ifOperStatus.10150
SNMP OK - up(1)
it return everything ok
if nagios core run the command it return an error
$USER1$/check_snmp -H $HOSTADDRESS$ -P 3 -U $USER3$ -L authPriv -a SHA -A $USER4$ -x AES -X $USER5$ -o IF-MIB::ifOperStatus.10150 (undefined)
-> IF-MIB::ifOperStatus.10150 <- this appear in RED. How can i resolve it?
kg2857
Re: Snmp Check Status
Post by kg2857 »
Are you running the test in the shell as the nagios user?
You might use snmptranslate to get the numeric OID and run the command with that.
Finally, are $USER4$ and $USER5$ defined?
TcoUpLoad
Post by TcoUpLoad »
First my apologies for so late response.
Answering to your questions, yes, i am running with nagios user. In my post is a mistake made by me, the (undefined) section is not an error but an indication that the 2nd argument is not defined.
In dashboard that command return UNKNOWN in the shell it return OK
Post Reply
