How to Install Nagios Agent to SUSE Enterprise version 15 SP2
Post Reply
hoegh
Post by hoegh »
How to Install Nagios Agent to SUSE Enterprise version 15 SP2?
https://www.nagios.org/ncpa/getting-started.php#linux
> Already performed this rpm -ivh ncpa-2.4.1.sle15.x86_64.rpm
> zypper install insserv-compat ncpa -y
Questions:
>Is this correct?
>How to get the "mytoken" for me to modify this /usr/local/ncpa/etc/ncpa.cfg
>How to check if Nagios agent is correctly installed in SUSE 15 SP2.
Höegh
kg2857
Re: How to Install Nagios Agent to SUSE Enterprise version 15 SP2
Post by kg2857 »
Follow the install from source instructions?
Post Reply
