Business Process Intelligence (BPI) Info URL Bug, Part 2
Post Reply
vornado
Post by vornado »
Part 1 was where if you clicked on a "URL" link, you would get an error because the URL was not created correctly. Apparently, this has been fixed.
The new issue seems to be that when you save the BPI record, the URL validation seems to require an extension such as .com or .net in the domain portion of the URL. Our intranet URL uses a server name without an extension, so there is no period. When I attempt to save a BPI record with one of your URLs, I get an error:
URL example:
Please correct the validation so that it allows URL with no extension in the domain name.
Thank you.
Steve Brown
Vornado Realty Trust
ajcoil
Re: Business Process Intelligence (BPI) Info URL Bug, Part 2
Post by ajcoil »
Hi @vornado,
Thank you for reaching out!
I wanted to inform you that this issue has been resolved since your last post!
Please feel free to reach out if you are still having issues!
Post Reply
