Nagios Core release updated - 4.4.12
Post Reply
Nagios Support
Post by Nagios Support »
Hey Nagios community, we've updated our original, open-source monitoring solution!
Check out the latest updates to see how Nagios Core 4.4.12 improves your open-source monitoring experience: https://bit.ly/42adUTj"
m.magnani
Re: Nagios Core release updated - 4.4.12
Post by m.magnani »
Greetings,
I'm having a strange problem with Nagios Core version 4.4.12.
When I upgraded Nagios Core from 4.4.11 to 4.4.12 I noticed that all the images next to the hosts are gone even if the upgrade shouldn't have changed paths/permissions.
if with the previous version I tried to go to this path from the web: http://ipnagios/nagios/images/logos/image.png I saw the image, after the update I get an error message saying "404 file not found", do you have any ideas?
Regards
Massimiliano
image with nagios 4.4.12.png (2.29 KiB) Viewed 2212 times
image with nagios 4.4.11.png (9.44 KiB) Viewed 2212 times
image with nagios 4.4.11 (2).png (2.26 KiB) Viewed 2212 times
Post Reply
