Kubernetes Check, WEB check not working
Post Reply
bancoatlas
Post by bancoatlas »
Hi there.
I'm facing a situation while trying to monitor a simple check regarding Kubernetes. So, here's what's happening: I configured a command and logged into my Azure account. When I run the command via CLI, whether logged in as root or as nagios, I receive a good response. Here are the outputs I get:
As root:
[root@v-svr /]# ./usr/local/nagios/libexec/check_kube_nodes.sh
OK - Kubernetes nodes all OK
As nagios:
[nagios@v-svr /]$ ./usr/local/nagios/libexec/check_kube_nodes.sh
However, the problem arises when I try to run the same command through Nagios Web. I don't receive any response there. The error message displayed on the Nagios Dashboard is as follows:
Error Message on Nagios Dashboard
CRITICAL - unable to connect to Kubernetes via kubectl!
Moreover, when I run the check command through CCM (Nagios Web), here's the output I get:
CCM Run Check Command
[[email protected] ~]$ /usr/local/nagios/libexec/check_kube_nodes.sh
BLANK RESULT
Can you please assist me with this issue?
Thank very much in advance
Command used to check kubernetes:
github.com/colebrooke/kubernetes-nagios
kg2857
Re: Kubernetes Check, WEB check not working
Post by kg2857 »
Manually running a check via ccm runs it as apache or some other user. Running it from the nagios scheduler runs as nagios.
Post Reply
