Nagios XI License and Trail version
Post Reply
sivakumar_mohan
Post by sivakumar_mohan »
Hi All,
We are looking for difference using Nagios XI Licensing and Trail version. As we are planning to move to trail version due to higher costing of licenses. Does it feasible, limitation or any challenges.
Siva
bv406
Re: Nagios XI License and Trail version
Post by bv406 »
NagiosXI free trial is up to 7 nodes or 100 checks, whichever you use up first.
Mikasa23
Post by Mikasa23 »
One challenge of using the Nagios XI trial version instead of the licensed version is the limited duration of the trial period,fnf which may restrict access to certain features and ongoing support after the trial expires.
nicklesta
Post by nicklesta »
One challenge of using the Nagios XI trial version instead of the licensed version is the limited duration of the trial period,geometry dash subzero which may restrict access to certain features and ongoing support after the trial expires.
Friend, if you don't mind, can you tell me in more detail about the limitations of the features in the trial?
kg2857
Post by kg2857 »
You might want to read what the nagios web site says the trial version features provide.
Post Reply
