Red Hat Enterprise Linux Server release 6.2 (Santiago)
64bit
Manual Install
External commands has stopped working suddenly, without to change anything.
System component status have some components down (see attach), and pnp graphs are not drawing. I suspect it could be a permission issue, but apparently all permissions are correct...
external commands not working
Re: external commands not working
And it seems nagios is seeing commands and services up...
Is crond running?
If it is stopped that may be the problem
service crond statusCode: Select all
service crond startRe: external commands not working
No, it is running...
crond (pid 2104) is running...
Lets try to restart it.
Also, lets tail the cron log
service crond restartAdditionally, can you post the output oftail -f /var/log/cron
df -hRe: external commands not working
Here the cron log:
Jul 20 11:29:01 localhost crond[9454]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9452]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9451]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9453]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9449]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9448]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9450]: (nagios) FAILED to authorize user with PAM
Jul 20 11:29:01 localhost crond[9447]: (nagios) FAILED to authorize user with PAM
This messages repeats every minute!
and the df -h
/dev/mapper/vg_00-lv_root
9,9G 5,3G 4,2G 56% /
tmpfs 1004M 0 1004M 0% /dev/shm
/dev/sda1 243M 87M 144M 38% /boot
/dev/mapper/vg_00-lv_home
9,9G 249M 9,2G 3% /home
/dev/mapper/vg_00-lv_tmp
1008M 35M 923M 4% /tmp
/dev/mapper/vg_00-lv_var
2,0G 1,3G 602M 69% /var
/dev/mapper/vg_00-lv_var_log
2,0G 1,6G 284M 86% /var/log
/dev/mapper/vg_00-lv_var_log_audit
2,0G 562M 1,4G 30% /var/log/audit
and the df -h
Problem solved!
It was a permission problem with nagios user.
Thanks for you help
Thanks for you help
I am glad you got this resolved! I will be locking this post now but if you have any more issues or questions, please, start a new thread.
