New Nagios XI install not adding any hosts
Post Reply
AlloyOfIron
Post by AlloyOfIron »
Hi All,
I have installed Nagios XI on a clean install CentOS 9 VM but I am having some troubles adding hosts and was hoping someone might be able to help.
I have tried adding both network switches via SNMP and some servers via the basic ICMP option as a test. Every time I get a sad face error with the server IP - "didn't send any data" (image attached)
Now I will admit, I am a noob with both Nagios XI and Linux but the install is so basic I can't see what I could have done wrong.
I do have all of my switches currently being monitored via LibreNMS without and I used the same SNMP details
Any assistance would be much appreciated :)
kg2857
Re: New Nagios XI install not adding any hosts
Post by kg2857 »
How are you adding hosts and switches?
Normally you add hosts via core configuration manage (CCM).
AlloyOfIron
Thanks for the response!
I have mainly been trying to add hosts via the configuration wizards but I also directly in the CCM. Both methods end up with the same error message.
kg2857
Post by kg2857 »
Look at the logs in /usr/local/nagiosxi/var.
Run the resonfigure script (not sure of the exact name) from the shell and read the output.
locate reconfigure
find /usr/local -type f | grep reconfigure
hrosegripping
Post by hrosegripping »
I've been using the setting wizards and the CCM's manual host addition features the most. The identical issue occurs when attempting either approach
gorilla tag
ZaneTapia
Post by ZaneTapia »
Ensure that SNMP is enabled and properly configured on the devices you are trying to monitor (switches,low’s adventures 3 servers). Since you mentioned these devices are being monitored by LibreNMS, the SNMP configuration might be correct, but it's worth double-checking.
cnorell
Developer
Post by cnorell »
AlloyOfIron,
To be clear, are you seeing the hosts and services being added in the CCM when you navigate to Configure > Core Configuration Manager, or are you not even getting that far? If the hosts and services are being added, the Hosts and Services counts should be incrementing in the CCM Object Summary on the aforementioned page.
Best Regards,
Cory Norell
Post Reply
