intercommunication between two nagios cores 4.x
Post Reply
tim1326
Post by tim1326 »
Hey fellow Members,
I am looking for a reliable way to exchange data between two Nagios cores (4.x).
More precisely, there is a main nagios core and a slave nagios core and I would like to send the data from the slave to the main in such a way that I can display them in the same way as the slave. Both systems are running on debian.
If it should be possible with NRDP, how do I have to set it up for both systems to send reliable and regular (passive) checks?
Thanks for your help in advance!
- Tim (:
kg2857
Re: intercommunication between two nagios cores 4.x
Post by kg2857 »
I'd think you'd copy from master to slave but anyway.
You should be able to copy the .cfg files from one to the other with scp.
Post Reply
