Monitoring services with wildcard
Post Reply
RickNWB
Post by RickNWB »
I have a few servers where I want to monitor some services. The problem is that the services will slightly change every 2/3 weeks. Is it possible to use a wildcard as a service? The service name is "Apache_7.7.79" and the next week it is "Apache_7.7.80" so is it possible to use a wildcard like "Apache_7.7.*"
Please let me know.
Rick
Mikasa23
Re: Monitoring services with wildcard
Post by Mikasa23 »
Hi Rick,
Yes, it is possible to use a wildcard in service monitoring to accommodate the changing service names. You can use a wildcard like "Apache_7.7.*" to monitor any service with aio games name starting with "Apache_7.7." followed by any version number.
RickNWB
Post by RickNWB »
Thank you for your response! Let's try it out
nehakakar
Post by nehakakar »
Yes you can create a service check using a wildcard like "Apache_7.7.*". This will match any service name that starts with "Apache_7.7." and has any value for the version number.
RickNWB
Post by RickNWB »
I don't get what to do. I tried a few things.
I created a service and I use the check command "check_XI_ncpa" but when I do that, I can't use the wildcard *. When I assign the service to a host, I receive a message that the service is unknown.
Has anyone a link how to do this?
kg2857
Post by kg2857 »
What happens if you run systemctl httpd status or systemctl and grep -i apache? My syntax could be off so...
RickNWB
Post by RickNWB »
Do I need to do that in "configure service" and under "monitor the service with this command"? Sorry, I am very new with Nagios
kg2857
Post by kg2857 »
You run the commands in the shell, such as an ssh session.
irfansst
Post by irfansst »
Yes, you can use wildcards to monitor services that change names frequently. I had a similar issue with my servers where the service names would change every few weeks. Using wildcards like "Apache_7.7.*" worked well for me.
I use an Uptime Monitoring Service to keep track of my servers. It costs me $60 per month for 60 monitors. This was essential for my business since I needed to monitor multiple services across several servers. The service has been very reliable, and it automatically adapts to name changes with wildcards, saving me a lot of manual work.
This setup ensures that I get timely alerts and can quickly address any issues, keeping my systems running smoothly. It’s been a great investment for maintaining service continuity and performance.
Post Reply
