NagiosXI socket timeout after 120 seconds
Post Reply
Shades007
Post by Shades007 »
Hi ,
Need some advise as we are currently facing issues whereby we are receiving errors for certain segments as below.
'CHECK_NRPE: Socket timeout after 120 seconds.'
Checks we have done from Nagios server as below.
1) ping - successful
2) telnet port 5666 - connected
3) traceroute - able to reach the destination server
Client server checks as below
1) port 5666 is listening
2) NRPE agent is up as well as restarted for good measure
3) 'check_nrpe -H localhost' - returns the NRPE version
We have checked firewall as well as network, we do not see any errors, yet we are still facing this issue. Please advise what other checks we can do to identify the issue.
Thanks in advance.
kg2857
Re: NagiosXI socket timeout after 120 seconds
Post by kg2857 »
You could search for nrpe troubleshooting which covers this issue.
Try running the check locally and see how long it takes to run.
Post Reply
