Warning / Critical notifications
Post Reply
JohnFLi
Post by JohnFLi »
Is it possible to make it so Warning alerts go to one set of contacts, and if it Critical have it send the alerts to another contact?
Everybody is somebody else’s weirdo
kg2857
Re: Warning / Critical notifications
Post by kg2857 »
Yes
bv406
Post by bv406 »
JohnFLi wrote: Thu Jul 13, 2023 11:48 am Is it possible to make it so Warning alerts go to one set of contacts, and if it Critical have it send the alerts to another contact?
Here are a couple documents I found on Nagios Answerhub on how to configure this:
https://answerhub.nagios.com/support/s/ ... y-57f2014a
https://answerhub.nagios.com/support/s/ ... s-15cb9953
https://answerhub.nagios.com/support/s/ ... s-abd1ff54
You can find more documents on https://answerhub.nagios.com/support/s/knowledge
JohnFLi
Post by JohnFLi »
Thank you bv406, I will look into it.
kg2857
Post by kg2857 »
Nonesensical
Post Reply
