RRDExport API
Post Reply
jarlathmallon
RRDExport API
Post by jarlathmallon »
Hi Folks
I am trying to use the RRDexport without having to put in the service description - is there a way to use a service_id or other unique identifier. The reason being is that the service descriptions all need URL encoded and get changed which breaks our RRDexport.
nagiosxi/api/v1/objects/rrdexport
Jarlath
kg2857
Re: RRDExport API
Post by kg2857 »
Have you tried rrdtool I think? It allows you to specify a file, that you can iterate on...
Post Reply
