(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or dire
Post Reply
pnikhade
Post by pnikhade »
I have newly setup Nagios and added one host for monitoring the CPU load & memory. But facing the below error,
(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
On my remote host nrpe is already installed & /usr/local/nagios/libexec has check_nrpe with proper permissions.
So please anyone suggest what can be the possible reason for this error because I believe check_nrpe is already present.
Piyush N
danderson
Re: (No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or
Post by danderson »
Thanks for reaching out @pnikhade,
Just to clarify, you have "/usr/local/nagios/libexec/check_nrpe" on the Nagios host and NRPE installed on the remote host, and you are getting this error on the Nagios host?
Butters
Post by Butters »
Would recommend to check if check_nrpe is with proper permissions and what check You are actually calling with it. Look for Your Command definition and the script/plugin you are calling and of course its permission and ownership.
Post Reply
