It looks like the latest version of XI is mangling the heck out of the nagiosxi logrotate file. After looking in to a disk space consumption issue I found that log files haven't been rotated in months. This is how the file sits on multiple systems I have checked, so there is a bug some where in the install that seems to not be replacing values for the logrotate file:
PRODDIR/var/*log {
missingok
notifempty
size 5M
copytruncate
su NAGIOSUSER NAGIOSGROUP
rotate 1
compress
PRODDIR/var/xidebug.log {
missingok
notifempty
size 100M
copytruncate
create 0660 APACHEUSER NAGIOSGROUP
su APACHEUSER NAGIOSGROUP
rotate 1
compress
PRODDIR/var/xidebug.log.backtrace {
missingok
notifempty
size 100M
copytruncate
rotate 1
compress
PRODDIR/var/components/auditlog.log {
missingok
notifempty
size 100M
copytruncate
rotate 1
compress
PRODDIR/tmp/phpmailer.log {
missingok
notifempty
size 100M
copytruncate
rotate 1
compress
I've already fixed my file and logrotate is working again, but anyone who's installed the latest version probably has a broken logrotate and growing log files now...
Prod XI: Debian 12 - Nagios XI 2024R2.1
Dev XI: Debian 12 - Nagios XI 2026R1
Hey @GldRush98, thanks for posting and I'm glad you were able to resolve the issue on your own.
There were some changes to the logrotate file with the 5.9.4 update and a sed was not added to the upgrade script to change those values. It has since been added. Here's the fix just in case:
