Scheduled Local Backup Failed
Post Reply
bseuser
Post by bseuser »
I see the scheduled backup is getting failed very frequently with the below message.
The scheduled local backup at 2023-08-14 05:55:03 failed.
Last output from the system:
View your full scheduled backup logs at /usr/local/nagiosxi/var/components/scheduledbackups.log to find out more details about the error. Your backup may have timed out, you can set a backup_timeout variable in config.inc.php to increase it.
Logs for reference.
# cat /usr/local/nagiosxi/var/components/scheduledbackups.log
No entry for terminal type "unknown";
using dumb terminal settings.
\nStarting new backup....\n
Backing up Nagios Core...
tar: Removing leading `/' from member names
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
tar: /usr/local/nagiosxi/var/sysstat.log: file changed as we read it
tar: /usr/local/nagiosxi/var/eventman.log: file changed as we read it
tar: /usr/local/nagiosxi/var: file changed as we read it
Backing up MRTG...
Backing up the SNMP directories
Backing up NRDP...
Backing up Nagvis...
Backing up nagios user home dir...
Backing up MySQL databases...
mysqldump: Got error: 144: "Table './nagios/nagios_statehistory' is marked as crashed and last (automatic?) repair failed" when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
-The previous post (from 2014) related to mysql password issues did not help me, can you let me know how to fix this issue?
-The MySQL database password hardcoded anywhere?
lgute
Re: Scheduled Local Backup Failed
Post by lgute »
Hi @bseuser, thanks for reaching out.
Try the following...
Log into the terminal as root and run the following command:
/usr/local/nagiosxi/scripts/repair_databases.sh
If you are still having issues, try the following command.
mysqlcheck -r -f -uroot -pnagiosxi --all-databases --use_frm
If the issue persists, please send us your system profile (if you can access through the XI interface).
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
-Laura
bbahn
Post by bbahn »
Hello bseuser,
From your log, it seems that your database (or at least one of your tables) is corrupted.
This indicates that the table/database may be corrupted. You can try repairing the database:
https://assets.nagios.com/downloads/nag ... tabase.pdf
This may be the actual cause of your failed backup and not the password as the log hint suggested.
-Blake Bahner
bseuser
Post by bseuser »
Hi,@lgute I tried repairing the DB with the commands you mentioned. Still i am facing the same issue sent you the system profile in a private message.
bseuser
Post by bseuser »
Hi @lgute
This issue still persists i shared the system profile with you in a private message. Can you review and suggest the next steps?
Post Reply
