Services in Unknown state
Post Reply
exjflog
Post by exjflog »
Hi, I have a server with CPU, Memory and uptime services in Unknown state, please help.
CPU usage: "NSClient - ERROR: Could not get data for 5".
Memory usage: "NSClient - ERROR: Error getting PDH value".
Uptime: NSClient - ERROR: Could not obtain value
kg2857
Re: Services in Unknown state
Post by kg2857 »
Is nsclient running on the host?
Are there other services that use nsclient on that host working?
Is nsclient configured the same on hosts that are running the same services?
sgardil
Post by sgardil »
Hey @exjflog
It's possible that you may need to modify the config files to fix this issue. Here is a link to another forum post with the same issue that might shed some light on a possible fix.
viewtopic.php?t=821
kevinrubio
Post by kevinrubio »
exjflog wrote: Thu Aug 24, 2023 4:47 pm Hi, I have a server with CPU, Memory and uptime services in Unknown state, please help.
geometry dash subzero
The easiest way is to restart the NSClient service on your server. It's my familiar way.
Post Reply
