After installing the Mrtg plug-in and applying the configuration as in the documentation, I got the message below. any idea?
check_mrtgtraf: Unable to process MRTG log file
Check_Mrtg not working
Re: Check_Mrtg not working
mrtg is a nagios-independent application and requires separate configuration
What is the result of running:
ls -al /var/lib/mrtg/
