Upgrade path
Upgrade path
Hi there, what would be the upgrade path, when our server is still based on the old CentOS 7 Core appliance, but NLS is version 2.1.15? Is it possible to export the configuration of the current NLS, and import it to a freshly installatie CentOS 9 Stream appliance?
Re: Upgrade path
Hello Narie,
While upgrading your Nagios Log Server (NLS) from an older version to a newer one involves several steps. I've provided you with a general outline of steps to take. You may also want to refer to the official Nagios documentation for "Backing Up And Restoring Nagios Log Server"
Here's a general outline of the process:
Let me know if you have any other questions or concerns.
-Mahad Mohamed
- Backup your current configuration: Before you start the upgrade process, it's crucial to back up your current configuration. This can be done from the NLS interface by navigating to "Admin" > "System Backups". Here, you can create a new backup which will include all your configuration data.
- Prepare the new server: Install CentOS 9 Stream on your new server. Make sure it meets the system requirements for NLS.
- Install the latest version of NLS: Download and install the latest version of NLS on your new server. You can find the latest version on the Nagios downloads page.
- Restore your backup on the new server: Once NLS is installed on the new server, you can restore the backup you created earlier. This can be done from the NLS interface by navigating to "Admin" > "System Backups". Here, you can upload and restore your backup file.
-Mahad Mohamed
Re: Upgrade path
Thank you for the clear answer. As always the documention was clear, complete and straight forward. The migration to the new server was flawless.
