Nagios logs growing up
Post Reply
providentpolska
Post by providentpolska »
Nagios logs growing up. Please help me if I can remove this logs? (paths below) without any issues? Or if is some script to trunkate it:
16G /usr/local/nagios
8.0G /usr/local/nagios/share
8.0G /usr/local/nagios/share/perfdata
7.6G /usr/local/nagios/var
7.6G /usr/local/nagios/var/archives
15G /usr/local/nagiosxi
3.0G /usr/local/nagiosxi/var/event_handler.log
6.4G /usr/local/nagiosxi/var/eventman.log
3.3G /usr/local/nagiosxi/var/sysstat.log
cbyers
Re: Nagios logs growing up
Post by cbyers »
Hello providentpolska,
Thank you for reaching out, you could run the following commands to empty the files.
echo '' > /usr/local/nagiosxi/var/event_handler.log
echo '' > /usr/local/nagiosxi/var/eventman.log
echo '' > /usr/local/nagiosxi/var/sysstat.log
As far as no issues that depends on how much you value those log files.
Cody Byers
providentpolska
Thank you, logs has been removed.
Post Reply
