nagiosxi - mariadb-11.2.1
Post Reply
efxSPN
Post by efxSPN »
Can you tell me if version 5.11.1 of nagios xi is compatible with mariadb-11.2.1?
itunixops
Re: nagiosxi - mariadb-11.2.1
Post by itunixops »
We actually used Mariadb 10.6.15 as it fixed alot of issues including alot of CVE fixes. Id not recommend any preview releases yet as that could unforseen issues.
swolf
Post by swolf »
Hi @efxSPN, thanks for reaching out.
I agree with @itunixops. You will "probably" find that the application "works" - we tend to write vendor-agnostic SQL queries on the backend, since we used to support the user's choice of Postgres/MySQL/MariaDB, with any versions that came pre-installed on our supported distributions.
That said, MariaDB 11.2.1 is not a supported configuration until we support a distribution that ships with it by default. You may run into issues with that, and you'll likely be on your own with diagnosing/fixing them.
I hope that helps - please let me know if you have any other questions or concerns. -Sebastian Wolf
Post Reply
