kabamaru
Posts: 11 Joined: Thu Sep 14, 2023 4:45 am
Post
by kabamaru » Fri Oct 06, 2023 4:04 am
Hello all
I am trying to use the
check_smart plugin on my nagios setup core 4.4.14. The plugin is here:
https://exchange.nagios.org/directory/P ... ng/details
When I run it locally on the host (Centos7), I get a result.
[root@dvv-1 libexec]# ./check_smart -d /dev/sdb -i auto
OK: Drive DELL MD32xx S/N 3C3005A: no SMART errors detected.
But I when I try it from nagios (Rocky 9), I get the following output:
[root@stoca plugins]# ./check_nrpe -H [i]hostname[/i] -c check_smart -a '-d /dev/sdb -i auto'
UNKNOWN: Drive S/N : No health status line found,
Is my syntax correct? Has anyone used this plugin before successfully?
Thank you
Yanni
kg2857
Posts: 511 Joined: Wed Apr 12, 2023 5:48 pm
Post
by kg2857 » Fri Oct 06, 2023 4:16 am
Plugins run as nagios, not root.
