Check_drivesize UNC PATH
Post Reply
alex24
Post by alex24 »
Dear nagios forum,
i need your help. I 'm using Nagios XI(5.6.10).
I'm already monitoring a few servers(mainly services, applications and local drives).
Now i'm trying to check network shares(check_nrpe with check_drivesize).
I've found something in here viewtopic.php?f=16&t=11745 and in here viewtopic.php?t=37151
But i'm not getting anywhere with it, i'm mainly using the GUI btw :
[[email protected] ~]$ /usr/local/nagios/libexec/check_nrpe -H 100.100.100.100 -t 30 -c check_drivesize -a drive='\\\\server\\share$'\
Exception processing request: Request command contained illegal metachars!
I would appreciate any ideas!
Cheers Alex
kg2857
Re: Check_drivesize UNC PATH
Post by kg2857 »
I'd guess it's the escaping of the UNC/windows paths. I'd first remove the escaping and use single quotes and if that fails change the escaping. Yes, it's a pain
alex24
Post by alex24 »
I also believe the windows path is the culprit, removed the escaping and used single quotes:
[[email protected] ~]$ /usr/local/nagios/libexec/check_nrpe -H 100.100.100.100 -t 30 -c check_drivesize -a drive='\\server\share'
What do you mean by change the escaping? Is there another escape character besides "\"?
Or is it becouse of nrpe as stated in here viewtopic.php?t=41191&start=10?
Post Reply
