check_http - How to check site using client certificate
Post Reply
alipoglavsek
Post by alipoglavsek »
I'm trying to monitor content of a website, which uses client certificate to for login.
Using option -K and -J doesn't work. I exported client certificate and private key to a PEM file/format, which I'm using with check_htttp plugin, but I still can't get any data from website.
We don't use any proxy.
Does anyone have a suggestion ?
lgute
Re: check_http - How to check site using client certificate
Post by lgute »
Hi @alipoglavsek, thanks for reaching out.
If I understand correctly, you need to monitor a website that is using client authentication certificates to control access to the website? Is this correct?
-Laura
Post Reply
