Inquiry about changing check_logfile output value.
Post Reply
chunsuk4u
Post by chunsuk4u »
hi. I am Korean and currently monitor systems and networks with Nagios.
I'm trying to analyze the server's log, and I've configured it with check_logfiles, and I'm currently very satisfied with it.
However, when printing [OK - no errors or warnings]
This part [/var/log/messages OK - no errors or warnings]
I would like to change it to. I am modifying line 1138 of the check_logfiles file, but it does not work, so I am asking this.
Please help.
swolf
Re: Inquiry about changing check_logfile output value.
Post by swolf »
Hi @chunsuk4u, thanks for reaching out.
First, this looks like it's related to a Nagios XI plugin, so I'm moving this thread to from Nagios Log Server to Nagios XI.
Second, I don't have a good answer for you. It looks to me like check_logfiles is a community plugin hosted on the Nagios Exchange. I would recommend reaching out to the plugin's author for advice on how to configure or modify it to better suit your environment.
Post Reply
