Missing author for acknowledgements
Post Reply
danielsj1
Post by danielsj1 »
Linux 3.10.0-1160.95.1.el7.x86_64
Red Hat Enterprise Linux Server release 7.9 (Maipo)
Nagios 5.11.2
Manual install
Attached an image of the issue. When I go to acknowledge something the author field is not populated despite being a locked field and when I got to submit the acknowledgement I get "Please fill out all required fields." So it won't go through.
sgardil
Re: Missing author for acknowledgements
Post by sgardil »
Hey @danielsj1
Sorry for the inconvenience. This is a known issue for 5.11.2 if the account attempting to acknowledge an issue doesn't have a ccm contact correlated to it. This will be fixed in 5.11.3. In the meantime if you would like to fix it you can replace your status-object-detail.inc.php file in /usr/local/nagiosxi/html/includes/components/xicore/ with the file attached after unzipping it or you can revert to a prior snapshot before upgrading. Like always we recommend making a snapshot before making any changes like these just in case.
danielsj1
Post by danielsj1 »
sgardil wrote: Thu Oct 19, 2023 9:34 am Hey @danielsj1
That worked, thanks!
Post Reply
