usr/bin/cfgmaker --no-down --noreversedns
Post Reply
patrickm1
Post by patrickm1 »
I'm getting this error. I doubled check the ip, I've changed to to aes, sha and still nothing. I was able to get it to connect awhile ago but canceled it after it connected. So, I'm not sure if it cached something. I've made sure SNMP is enabled on the device and made sure the Nagios LX server ip is allowed. Any thoughts or idea?
/usr/bin/cfgmaker --no-down --noreversedns --if-template=/usr/local/nagiosxi/html/includes/configwizards/switch/templat
bbahn
Re: usr/bin/cfgmaker --no-down --noreversedns
Post by bbahn »
Hello patrickm1,
Can you post here what your error output is?
Also it seems that you made a typo here
should be
/usr/bin/cfgmaker --no-down --noreversedns --if-template=/usr/local/nagiosxi/html/includes/configwizards/switch/template
Post Reply
