Annoying web login user issue
Post Reply
colinjack
Post by colinjack »
Firstly I must state that this is not a critical problem! It is just bugging me. :?
I have Nagios Core 4.4.14 running on a Raspberry Pi with PiHole - so using Lighty rather than Apache.
Everything is running fine except that although I only login as nagiosadmin on the web interface it says "Logged in as nagiosadmin, user, user (see attached).
This means that I have to set all authorized_for = settings to * rather than nagiosadmin in cgi.cfg otherwise I get permission errors.
My question is if I am logging in as nagiosadmin where on earth is it getting user from?
I have been through all the config files and can't find anything. Obviously I'm missing something but I have been trawling through for days.
I only have nagiosadmin in htpasswd.
Anybody able to help?
Colin
colinjack
Re: Annoying web login user issue
Post by colinjack »
Found it!!
Lighttpd nagios.conf file had this:
setenv.add-environment = ( "REMOTE_USER" => "user" )
Removed it and all sweetness. :D
Colin
Post Reply
