Anyone knows how I can stop the alerting between CRITICAL state changes? More specifically, when a host is down, I don't want to get notified for a state change to unreachable or vice versa, is this possible?
Kind Regards
State changes between DOWN - UNR
gwesterman
Re: State changes between DOWN - UNR
Hi @coitop,
This may not be exactly what you are looking for, but there is an option in Core Config Manager -> Hosts or Services, when you select a host or service, to select specific notification options (e.g. only for a "down" or "unreachable" state or both "down" and "unreachable") under the Alert Settings tab. Additionally, you can set these settings for specific contact groups.
Let us know if this helped and if you have any more questions.
I knew about this solution but it's fine. I'll figure it out somehow and if I can't implement it, it's fine I guess. Was just looking if it exists or not.
You may close this thread.
Kind Regards
Kind Regards
