NagiosXI 5.11.3 Install on 9-Stream
Post Reply
snapier3
Post by snapier3 »
Ran into an issue with running the full install of 5.11.3
In line 105 of the ./fullinstall script the is a call to format the install with tput
This caused a failure
I changed this back to the "cat <<-EOF" command as in the rest of the script and it worked just fine
NOTE
This is 9-Stream running in LXD
lgute
Re: NagiosXI 5.11.3 Install on 9-Stream
Post by lgute »
Hi @snapier3,
Thank you for that information. I will pass that along to support and development.
-Laura
cdienger
Post by cdienger »
@snapier3, What was the error you received exactly? Is tput and fmt installed on the system?
Post Reply
