Update Warnings, Standalone Check
vornado
Post by vornado »
Good morning, all.
After updating to version 5.11.3, the log showed some warnings followed by the total number of warnings. I made the corrections as indicated in the warnings. Is there a standalone way to check that I've gotten rid of all the warnings? Or do I have to wait until the next update?
All of the warnings were about services that had notification intervals less than their check intervals. Here are a few examples.
Warning: Service 'DNS IP Match' on host 'Bizflow Disaster Recovery Server C155MGAUS01' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'DNS Resolution' on host 'Bizflow Disaster Recovery Server C155MGAUS01' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Warning: Service 'HTTP' on host 'Bizflow Disaster Recovery Server C155MGAUS01' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval.
Thanks for your help.
Steve
sgardil
Re: Update Warnings, Standalone Check
Post by sgardil »
Hey @vornado
I believe you can check /usr/local/nagios/var/nagios.log for errors like these. Let us know if these are what you are looking for.
gwesterman
Post by gwesterman »
Hi @vornado,
You can also run this script:
which will give you warning or error messages if you have anything misconfigured.
Hope this helps!
vornado
Post by vornado »
Thanks, @gwesterman, that looks like it worked:
Nagios Core 4.4.13
Copyright (c) 2009-present Nagios Core Development Team and Community Contributo        rs
Last Modified: 2023-06-01
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 491 services.
        Checked 77 hosts.
        Checked 7 host groups.
        Checked 45 service groups.
        Checked 30 contacts.
        Checked 2 contact groups.
        Checked 150 commands.
        Checked 36 time periods.
        Checked 0 host escalations.
        Checked 77 hosts
        Checked 0 host dependencies
        Checked 36 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
jsimon
Post by jsimon »
Hey @vornado, it looks like your issue is resolved so I'm going to go ahead and lock the topic.
