Nagios XI installation and configuration
nagios_asesh
Post by nagios_asesh »
We are learning Nagios XI, when the installation is completed don't know what is the default login account, for Naigos XI installation and configuration of the reference documentation.
Re: Nagios XI installation and configuration
Type in the address bar of your browser:
http://<xiserver_IP>/nagiosxi
username: nagiosadmin
password: whatever password you set up initially
Note: If you forgot the password, you can reset it, following this document:
http://support.nagios.com/wiki/index.ph ... n_Password
Hope this helps.
