NagiosXI logrotate not working
Post Reply
elpakko
Post by elpakko »
I read somewhere that NagiosXI should have automatic Logrotation feature. I have noticed that perhaps the logrotate is not working, because my log files are getting big. I have not touched the logrotate conf files, but is there something I should configure for the logrotate to start working?
The settings are at the moment:
PRODDIR/var/*log {
missingok
notifempty
size 5M
copytruncate
su NAGIOSUSER NAGIOSGROUP
rotate 1
compress
PRODDIR/var/xidebug.log {
missingok
notifempty
size 100M
copytruncate
create 0660 APACHEUSER NAGIOSGROUP
su APACHEUSER NAGIOSGROUP
rotate 1
compress
PRODDIR/var/xidebug.log.backtrace {
missingok
notifempty
size 100M
copytruncate
rotate 1
compress
PRODDIR/var/components/auditlog.log {
missingok
notifempty
size 100M
copytruncate
rotate 1
compress
PRODDIR/tmp/phpmailer.log {
missingok
notifempty
size 100M
copytruncate
rotate 1
compress
When I run
"logrotate -d /etc/logrotate.d/nagiosxi"
I get:
reading config file /etc/logrotate.d/nagiosxi
error: /etc/logrotate.d/nagiosxi:1 unknown option 'PRODDIR' -- ignoring line
error: /etc/logrotate.d/nagiosxi:6 unknown user 'NAGIOSUSER'
lgute
Re: NagiosXI logrotate not working
Post by lgute »
Hi @elpakko, thanks for reaching out.
What version of XI are you using and what OS & version? There have been a few fixes released lately that may address this issue for you.
This post may also address the issues you are having.
-Laura
elpakko
Post by elpakko »
Hi, thanks for your message.
I'm using the latest NagiosXI version 5.11.3 and Ubuntu 22.04 LTS with all the latest updates installed. I think this problem has been around for awhile, because sysstat.log is more than 13G in size.
elpakko
Post by elpakko »
@lgute
Any ideas on what to do? Should I try the command from the other post you suggested?
lgute
Post by lgute »
Hi @elpakko,
Please run the following to correct the log rotation issue. It does appear to be the same issue as the post I linked to.
. /usr/local/nagiosxi/etc/xi-sys.cfg
sed -i "s|APACHEUSER|$apacheuser|;s|NAGIOSGROUP|$nagiosgroup|;s|NAGIOSUSER|$nagiosuser|;s|PRODDIR|$proddir|" /etc/logrotate.d/nagiosxi
One more question. Is this a new install or an upgrade? If upgrade, what was the last version you upgraded from?
-Laura
elpakko
Post by elpakko »
Thanks, I ran the command and now the logrotate seems to be working again. The previous version was 5.11.2 but according to lograte info, the last succesfull rotation was 17.5.2023. So looking at my upgrade history, it seems that it was broken in the upgrade from 5.9.3 to 5.10.0
lgute
Post by lgute »
@elpakko,
Thank you for the update. I am glad that resolved your issue.
-Laura
Post Reply
