Upgrading Nagios cluster from 5.7 to 5.11 failed
Post Reply
arista-nagios
Post by arista-nagios »
I have a Nagios cluster of two nodes configured with pacemaker corosync and drbd.
Nagios version: 5.7
upgrading to: 5.11.3
Reference article: https://assets.nagios.com/downloads/nag ... ctions.pdf
Error:
*** Configuration summary for ***:
User: nagios
Group: nagios
Bin directory: /usr/local/nagios/bin
Config directory: /usr/local/nagios/etc
Nagios config: /usr/local/nagios/etc/nagios.cfg
Review the options above for accuracy. If they look okay,
type 'make all' to compile NDOUtils, or type 'make' to get
a list of make options.
cd src/ && make ndo.so
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/ndo/ndo-3.1.0/src'
gcc -fPIC -shared -g -O2 -I/usr/include/mysql ndo.c -o ndo.so -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto -pthread
ndo.c:155:12: warning: ‘database_instance_id’ initialized and declared ‘extern’ [enabled by default]
extern int database_instance_id = 1;
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/ndo/ndo-3.1.0/src'
make[1]: `ndo.so' is up to date.
/usr/bin/install -c -m 774 -o nagios -g nagios src/ndo.so /usr/local/nagios/bin/ndo.so
Shared module ndo.so installed
/usr/local/nagios/etc/nagios.cfg configured to use NDO
UPGRADE: POST-UPGRADE: NDO post upgrade started...
Performing upgrade...
> Upgrading from version 3.0.4 (/tmp/nagiosxi/subcomponents/ndo/ndo-3.1.0/db/upgrade-from-3.0.4.sql)
ERROR 144 (HY000) at line 7: Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed
Automated migration failed on file upgrade-from-3.0.4.sql!
The 'nagios' database is not in a usable configuration.
Please revert to your pre-upgrade snapshot and reach out to the Support Team.
jsimon
Re: Upgrading Nagios cluster from 5.7 to 5.11 failed
Post by jsimon »
Hi @arista-nagios,
I would recommend running the following command to repair your database:
cd /usr/local/nagiosxi/scripts/
./repair_databases.sh
If you run into errors running this, please follow up and let us know what Linux distro your server is installed on, as there are some more steps to take if the repair_databases.sh script isn't successful, but they are distro-dependant.
arista-nagios
I possess a Nagios XI license and need to arrange a meeting to address challenges encountered during the Nagios cluster upgrade. This is urgent for us. I noticed a 'community support forum for Nagios commercial products' at the top of the page. Is this the enterprise support portal, or could you redirect me to the correct Nagios XI enterprise support portal?
jmichaelson
Post by jmichaelson »
This is not the enterprise support portal. Enterprise support information can be found her: https://www.nagios.com/support-plans/
-Jason
arista-nagios
Yes, is there any guide or document to upgrade a nagios-cluster?
Repairing the db fixed my nagios but I still need to update it to the latest version.
jsimon
Post by jsimon »
Yes, you can follow this guide to update your Nagios XI to the latest version:
Post Reply
