Backupxi failed -"Scheduled Local Backup Failed"
Post Reply
igae1
Post by igae1 »
We have recived the following notification:
"Scheduled Local Backup Failed, Last output from the system: Error backing up MySQL database 'nagios' - check the password in this script!"
We have checked that the password in this script is correct, because is the password of the configuration file /usr/local/nagiosxi/etc/xi-sys.cfg
We have sucesfully connected to the mysql database nagios with the user and passw0rd stored in configuration file /usr/local/nagiosxi/etc/xi-sys.cfg
This is the backup daily of mysql nagios:
MySQL dump 10.14 Distrib 5.5.68-MariaDB, for Linux (x86_64)
-- Host: localhost Database: nagios
-- Server version 5.5.68-MariaDB
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
/*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */;
/*!40103 SET TIME_ZONE='+00:00' */;
/*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
/*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
/*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
/*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
-- Current Database: `nagios`
CREATE DATABASE /*!32312 IF NOT EXISTS*/ `nagios` /*!40100 DEFAULT CHARACTER SET utf8 */;
USE `nagios`;
Tnaks
igae1
Re: Backupxi failed -"Scheduled Local Backup Failed"
Post by igae1 »
backup keeps failing
igae1
Post by igae1 »
This issue is already solved.
We have run a restore database job yesterday and it worked today.
Post Reply
